Honeywell Zone Valve
Old 02-17-10, 03:51 AM
B
I have a Honeywell Zone valve (model number V8053E1012) on my 10 year old furnace. It is sticking in the open position. It closes when I tap it with my fingers. Is this a problem with the motor or does the whole Zone Valve have to be replaced?
Old 02-17-10, 05:23 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Zone Valve
It could be either but I'd try a new motor first. Motors are a whole bunch cheaper & easier to replace than the whole valve. Even if it turns out to be the valve, keep the motor. Sooner or later you will likely need it.
BTW, are you sure the number isn't a V8043 not v8053?
Old 02-18-10, 07:44 AM
B
Yes the number is V8043. Actually the whole number is V8043A1185. I can't find this same part number but I did find V8043E1012. Will this one work?
Old 02-19-10, 03:03 PM
Grady's Avatar
Zone Valve
Sorry for the delay in responding but I couldn't get on the board last nite for some reason.
I could not find out anything at all about the existing zone valve. It seems to be an OEM part. Is the boiler, by any chance, a System 2000?
Old 02-20-10, 05:30 AM
B
Yes I do have a System 2000
Old 02-20-10, 05:57 AM
Grady's Avatar
System 2000
If I remember correctly, they used a zone valve other than the normal 3.5 CV but unless the zone in question has a very high flow requirement the V8043E1012 will be fine. In fact, the power heads are interchangeable. I still suspect the problem to be just the motor.
Old 02-20-10, 12:05 PM
B
Thank you Grady. I have ordered a replacement motor. I'll let you know the outcome. Thanks for your help.
Old 02-25-10, 09:21 AM
B
Zone Valve
Replaced motor as you suggested. Zone valve now works fine. Thank you.
Old 02-25-10, 04:22 PM
Grady's Avatar
Zone Valve
You are most welcome. Glad I was right & you were able to save some time & money. I feel bad when I suggest something to a poster & my advice ends up being incorrect.
Should any other problems crop up around the house there is a forum on doityourself.com to cover it. Each is frequented by people willing to help.
