gas furnace/water heater room ventilation
Old 06-19-10, 05:39 PM
H
My furnace & water heater are in a room apprx 8 X 12. regular dyrwall construction w/ interior door. (i think gravity fed hood furnace....???BTU's)
I've been told i should a install louver door or cut a hole in the drywall and install a metal louver vent to allow furnace to breath easier and avoid carbon dioxide build-up.
For 6 yrs the room has remained unchanged w/ a cabon dioxide detector in the room and its never gone off. I'm doing some work in the basement and feel if I should install a vent i should do it now.
does this sound like something i need to do??
thanks
Old 06-20-10, 11:02 AM
F
Fuel needs air (specifically oxygen) to burn and if the fuel does not get enough air the products of combustion can be hazardous to health. From what you have described I would most definitely add venting/ductwork to the outside air to this room. The specifics are readily obtainable and they are based upon the total BTU rating of the gas-burning appliances. I can probably find some guidelines for you if needed.
Old 06-20-10, 03:30 PM
H
thanks.....i will add a vent
Old 06-20-10, 04:30 PM
F
I strongly urge you to read pages eight and nine of the linked pdf file.
http://www.dnmech.com/lit/io-554.pdf
Also read this link.
FIELD CONTROLS, LLC - CONTRACTOR PRODUCTS Combustion Air Systems
Old 06-21-10, 12:21 PM
1
Received 1 Upvote on 1 Post
Code state a air intake equal to 1" square per 1000 input. ie: 100k input would need a 10 x 10 register installed.
Also most codes require 2 vents installed, one near the floor and one near the ceiling.
Old 11-27-14, 07:00 AM
B
What if the heating appliance is high efficiency gas that uses exterior supplied intake and exhaust? Same guidelines apply?
Old 11-27-14, 07:56 AM
Grady's Avatar
Received 39 Upvotes on 37 Posts
If the furnace uses outside air for combustion, you only need to be concerned with any other appliances (water heater, dryer, etc.) which may share combustion air from within the room.
Old 11-28-14, 06:28 AM
B
Thanks Grady! Nothing else but electric water heater in the space.
