Heater/Hot Water System Temperature?
Old 12-03-00, 01:54 PM
Guest
What temperature setting should I use for mmy hot water/ heating system. It was set at 150 degrees and it wasn't able to keep up with on demand use. How hot is too hot?
TIA
Old 12-03-00, 04:40 PM
R-12guy
Im takeing this tobe a hot water baseboard boiler type set up.... if so raise the temp up to 180, I wouldnt go over 200
Old 12-03-00, 05:04 PM
Guest
Thanks but its actually
Actuallly the boiler handles steam radiator heat for the house and hot water usage. It doesn't have a water tank per se but heats the water as needed. Or so I'm told.
Thanks again
