A2VA7116 (Suntec) for Beckett AFII
Old 09-26-10, 01:35 AM
F
I recently replaced the A2VA7116 (Suntec) pump with a used conventional pump without Suntec for my Beckett AFII oil burner and the burner did not ignite. Does this mean that I cannot use the conventional pump on the newer generation of burner? Thanks.
Old 09-26-10, 01:00 PM
E
Received 1 Upvote on 1 Post
Did you prime the new pump?
Old 09-27-10, 07:51 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Conventional Pump?
What do you mean by a "conventional" pump? The A2VA-7116 is hardly state of the art. What is the make & model of the furnace? (Most AFII burners use a higher than "standard" pump pressure.)
