Carrier Furnace model # 58MSA080-12
Old 09-27-10, 08:33 AM
P
The status code led is flashing. The fan is keep on running but there is no flame coming out of the burner. Please help.
Old 09-27-10, 09:17 AM
G
Received 2 Upvotes on 2 Posts
Welcome to the forums. On the inside of the furnace, usually on the back of one of the cover panels or the sides, should be a list of what the LED flashes are saying. Count the flashes and check the list.
Also, which blower is running, the small inducer fan or the main blower which pushes air throughout the house?
Old 09-27-10, 03:34 PM
E
Received 1 Upvote on 1 Post
I guess it is the inducer, and the furnace went into lockout for some reason, during the call for heat, with the set temp at the stat not being met, keeping the inducer running.
Need poster to tell us what they observe with the big furnace panel door off after they - shut off the furnace switch or circuit breaker to furnace to let it reset. Then turn furnace switch or breaker back on, turn up the stat, then look in the big furnace panel door to tell us what happens in the burner compartment. Does your furnace have a pilot that automatically lights or does yours have something that glows to make the gas fire off?
