how to adjust type A draft control on old furnace
Old 10-03-10, 07:33 AM
D
Pro's, I know you have an answer, how do I adjust the draft control on my oil furnace? It has a type A draft vent control with that little weight that can be threaded in or out. I noticed the nuts were loose on this weight so I tightened them, now where do I set the weight? Should the damper only open when the furnace first fires? Should it always be open a bit? I want to make sure I have it correct. I first noticed it when I fired the furnace for the first time this season, I smelled exhaust in the basement where the furnace is located. I am going to clean the pipes leading into the chimney to be safe and make sure there are no blockages in the flue also.
Let me hear.
DanO
Old 10-03-10, 02:27 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Draft Control
To properly adjust a draft control one needs a draft gauge but a good starting point is to adjust the weight so the damper is closed but will open somewhat with the slightest tap of your finger.
