Heat Pump
Old 12-13-00, 07:41 AM
Guest
Question
I have a Rheem Heat Pump. It is a split-unit with the air handler under the floor. My air handler will not stop running. I can turn my heat completely off and the air continues to blow. I have even turned off the main breaker for an entire day, and when I turn it back on, the air still blows. What could be causing this?
Old 12-13-00, 08:14 AM
Mike Swearingen's Avatar
Cool
I hate to ask this, but has someone, unbeknownst to you, flipped your fan control from "auto" to "on" on your thermostat(s)? (Happens in this house. lol)
Old 12-13-00, 02:47 PM
fjrachel
If you don't have your fan switch in the on position instead of auto, there may be fused contacts fan relay, bad t'stat, bad control wiring.
Old 12-13-00, 07:56 PM
Guest
Heat Pump
The fan switch has set to "auto".
