coleman furnace
Old 12-13-00, 09:51 AM
Guest
my furnace fan comes on but for only a few seconds at a time
Old 12-13-00, 02:06 PM
PDF
Need more info
How old is the unit?Is your filter clean?Place your tstat to the "fan on" position to see if the fan will run in this position.Give us a reply back and we will try to assist you further.PDF
Old 12-13-00, 03:46 PM
fjrachel
need alittle more information. Is this a trailer, single or double wide type coleman? Or house unit? Also please watch and make sure burner(s) are coming on and staying on. If it is your fan thermo disc is bad if your in a trailer, single or double wide.
Old 12-13-00, 09:09 PM
Guest
coleman furnace
its a 1979 singlewide trailer. and the burner stays lit.clean filters.
Old 12-14-00, 02:26 PM
fjrachel
Definitely the thermo disc then. In the control area you will see a disc about the size of a quater. With two wires. Turn off electric, jumper the wires, and turn electric on. The fan should come on. If not try the heat and it should come on. You can get the disc from any coleman dealer.
