Furnace Gas Valve Replacement
Old 10-09-10, 05:47 AM
R
Question Furnace Gas Valve Replacement
My 1988 Snyder General furnace's pilot won't stay lit. I replaced the thermocouple, but, that didn't help. Called service man. He said the gas valve needs replaced. Through him it will cost >450! So he mentioned replacing the whole furnace go figure. Anyway, to my question...it has a 36C03 type 245 gas valve, can I replace it with a 36C03 type 333??
thanks in advance
Old 10-09-10, 03:08 PM
Received 3 Upvotes on 3 Posts
Seems like a standard replacement gas valve.
//www.google.com/products/catalog?client=safari&rls=en&q=white+rodgers+36c03+333+gas+valve&oe=UTF-8&um=1&ie=UTF-8&cid=2975242924767001686&ei=8-ewTML
Do you know how to set the pressure? If no, I would call your Gas co after you do install and have them check the input, which translates to clocking the meter and checking the pressure.
Old 10-10-10, 04:05 AM
R
thanks for the reply mbk3. That's what I figured with the replacement. And, no, I don't know how to check the input. I will have somebody come in to check this. thanks again
