Vent Pipe recommendation
Old 10-10-10, 10:36 PM
Question Vent Pipe recommendation
Which "vent pipe" brand do you recommend? Like, which brands do you use? (I'm talking about the pipe which connects the oil-furnace to the chimmney).
Selkirk Corporation?
Lambro?
Also, which series do you recommned? This is for a residential oil-fired upflow furnace (131,000 BTU/hr).
Old 10-12-10, 06:38 PM
Grady's Avatar
Received 23 Votes on 21 Posts
Vent Pipe
I use 24 gauge galvanized pipe I get at my local supply houses. The brands stocked around here are Gray & Southmark(?).
If your pipe was taped due to debris coming out of the joints, the joints can be sealed with high temperature silicone available at HVAC & some Plumbing suppy houses (not likely to be found at a big box home store).
