ac motors
I know you can change rotation direction on dc motors but
can you change motor rotation direction on ac motors?
thank you
Jackjacklee
thank you
Jackjacklee
Y E P !!!!
Some motors have 2 leads to reverse rotation.The directions will be listed on the motor or on the inside of the electrical plate.This can be done by changing 2 wires.Once the electrical plate is removed you will see that the wires are color coded or numbered,follow the directions.Some ac motors require removing the long motor bolts,pulling the armature assembly from one end and inserting into the other end,then reinstalling the bolts.This can only be done on certain motors.PDF
