changing filer
Old 12-15-00, 11:59 AM
Guest
I have a new Janitrol furnace, model #GMP075-3. Where is the filter located and how do I get to it?
Old 12-15-00, 01:57 PM
PDF
Call install people
Call your install company.They should have run you thru the paces on customer maintenance,explained system operation and answered your ?s at that time.Where was your filter located prior to the change out?If your new system incorporates a filter make sure you remove your existing filter if it is in a hinged return grille.PDF
Old 12-15-00, 02:29 PM
fjrachel
Goodman's filter rack is in the lower front panel of the furnace, if the filter accessory was installed. Most companay's will cut a filter slot into the return air duct near where it goes into the furnace. Call the installing comapany and ask, as PDF suggests, if you can't find one.
