Furnace will not fire up
Old 10-26-10, 05:30 AM
Z
I have a Utica gas fired boiler.Model # is MGB125HD. It has a Field Control (gas vent damper).
My problem is that when I call for heat,I hear a click,but,the burners do not come on. In the past,I am pretty sure that when a call for heat was placed,the vent damper would open followed by the burners coming on. Well,the damper is not opening.
Is the damper bad? Anyone have an idea before I call someone?
PS: On the damper,there is a survice switch that is set on automatic. Is it safe to set the switch the other way which will open the damper? Can I then put in a call for heat to see if the burners fire up?
Old 10-26-10, 07:20 PM
Z
Over 30replies,and noone has any ideas?
Old 10-26-10, 07:48 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
Yes, the damper should open.
The trouble is, if you make a mistake on a vent damper you could wind up with the combustion gasses coming in the house.
Not something I care to offer DIY advice on.
Old 10-27-10, 06:26 PM
Z
Soooo,I moved the service switch on the damper to "hold open". I then put in a call for heat which opened the damper followed by the burners,and then,heat. I then turned down the thermostat,the burners stopped,and the damper closed.
I then set the service switch to "automatic",put in a call for heat,but,the damper did not open which did not allow the burners to come on.
Is it safe to say the gas vent damper is bad? Ideas?
Old 10-29-10, 06:28 PM
Z
Thank you for the reply Seattle Pioneer. To everyone else,you are useless.
Bad damper...easy fix......
