Furnace won't come on
Old 12-16-00, 10:03 AM
Guest
Question
Hi,
Gas furnace won't start. I've checked the thermostat and the fuse box - All okay. The pilot light is lit and the fan will come on (in manual mode).
Is there anything else I should check?
Thanks,
MC
Old 12-16-00, 10:18 AM
fjrachel
First try this to eliminate the t'stat. Remove t'stat from sub-base, then jumper the 'w' and 'r'. If furnace comes on t'stat is bad. If not, you probably are out on a safty device in the furnace or have a bad gas valve. Call a tech to check out.
