Damper Setting - Oil Furnace
Old 12-16-00, 04:33 PM
Guest
How do I know whether damper is adjusted properly? Is there an easy way to tell?
Old 12-16-00, 05:06 PM
fjrachel
What damper? The one on the flue?
Old 12-17-00, 05:43 AM
Guest
My question refers to the damper which is in the chimney pipe, outside the furnace.
Old 12-17-00, 06:10 AM
fjrachel
It should be set horizontal to the floor. Most have a large weighted knob for balance. Adjust the balance knob till the bottom of the damper starts to lean inward towards the chimney, then back of a 1/4 turn. Usually this damper only moves on start up then settles out after a minute or so.
