Miller furnace issues
Old 11-11-10, 01:49 PM
E
Wink Miller furnace issues
Miller furnace runs fine then wont run at all until i unplug the plug behind the door switch.i unpluged the door switch an things where fine until this started.just hoping someone can help me out thanks its a gas furnace
Old 11-11-10, 04:52 PM
E
Received 1 Upvote on 1 Post
This is a little confusing the way you put it. Could you put the words better so we know which occured first about the furnace not working, and what role the door switch played? And what made you think to disconnect the door switch since it is common knowledge that the door switch has to be hooked up to make the furnace RUN, rather than NOT run? ???
