Not kicking on, always on?
Old 11-29-10, 04:08 PM
A
Hi!
We have a gas Lennox furnace. I don't know if this is normal, but it always sounds like it is "on" -- similar to the sound of the water heater. I'm not sure if it's the burners or the inducer motor (it's not the main blower fan).
Anyway, it could be related (or not) but it hasn't been keeping the temperature up to that of the thermostat. For example, we have it set to 70 (normally not that high) and it's content at 63. If we crank it higher it seems to kick on.
Any ideas?
Old 11-29-10, 04:30 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
Is it the fan that circulates the air around the house that is on?
You need to take the cover off the furnace burner compartment and carefully observe what is happening and report that here.
Old 11-29-10, 04:35 PM
A
No, the fan isn't always on.
I took the cover off but it's hard to pinpoint what the sound is. It sounds just like the water heater. Not sure if it's a burner or inducer motor.
Old 11-29-10, 07:09 PM
A
I think it was the flame sensor.... problem... solved??
