forced heat furnace blowing cool air
Old 12-03-10, 08:36 AM
F
hello,
i have a forced air heater and i read alot about them and tried to understand as much as i could. i know they include a cool air register. my register is on the floor in the hallway of 3 bedrooms, but i understand its supposed to suck air, not blow air. there is another register towards the bottom of my living room wall ( i think its a register) it blows cool air too. unit was already there when i moved in. i found out it was installed december 2001. per model number its a 1999 unit. fueled with natural gas.
the other vents, they are high on the walls, and blow warm air. checked filter and cleaned it. any ideas, or would this be normal fucntioning of a forced air heater.
thanks for any replies.
Old 12-03-10, 08:46 AM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Could you give make and model of your unit? Do you have A/C? Make, Model?
Old 12-03-10, 08:58 AM
F
model # NTN6100KJA1, brand ICT. think it stands for international comfort...something. i'm sorry i'm not at home and trying to remember. the ac unit is outside the house on the floor. right now all i can tell your its a HEIL brand. thanks for the quick reply.
Old 12-03-10, 09:00 AM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
You may have two return air registers. That would not be unusual.
Old 12-03-10, 09:12 AM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
If they are actually OUTPUTTING cold air when the heat is running...that would be unusual. They should be sucking in room temp air.
I think you might need to trace the actual ducting back and make sure they are connected properly. If one duct has come loose it may be sucking attic or crawlspace air somehow?
Old 12-03-10, 01:48 PM
F
i appreciate the replies. i'll see if i can figure out a way to get inside and see how the ducts are connected.
