Is my furnace oversized and efficient?
Old 12-04-10, 09:46 AM
F
I bought a house in the Detroit MI area in 2008. It was built in 1934. The furnace is forced air gas Ducane Model MPGA075B3 that is 80% with 75000 btu input. There is also central air attached to the furnace.
The house has a 563 sqft basement, 582 sqft main floor over the basement, 213 sqft addition not over the basement and 332 sqft second floor. There is a supply to the addition with an inline fan. There are 4 supplies and 2 returns on the main floor. The upstairs has 2 supply and 1 return duct.
I have the thermostat set at 60 F. I am only heating the main floor of 582 sqft. It has used 400 ccf for the last 2 winters.
Is the furnace the proper size?
Is the amount of gas used reasonable?
Old 12-04-10, 10:17 AM
Skip4661's Avatar
There are many factors to consider when sizing a furnace. There are programs available on the net to help you figure the heating requirements of your home. Search the net for heat load calculators.
Old 12-04-10, 06:11 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
What is your gas bill for the month or on cold months??? Your bill in the coldest month with 582 sq feet( if thats where the t stat is should be around $ 150)
Yes????
Mike NJ
Old 12-05-10, 10:31 AM
F
The cost of gas is about $1 per ccf (100 cu ft). In the coldest month of January, the bill is over $100.
