Aireflo (3 Years Old) Induction fan Always on, Getting no heat
Old 12-04-10, 06:43 PM
R
Aireflo (3 Years Old) Inducer fan Always on, Getting no heat
I was trying to connect my super old humidifer to 24 volt power supply but accidently connected to 120 Volt side (dont ask). Now the inducer fan is always on and I got no heat. Im also getting 3 flashes on the LED which according to the diagram is "Pressure switch stuck closed or open". Does the fan blow or suck the pressure switch? Im guessing it blows. When I put a little suction on the hose, I can hear a click but when I blow, I dont really hear anything.
I can get a heat cycle when I put suction on tube and reconnect tube to fan.
What do I need? New pressure switch or board?
Please help
Aire Flo AF80MPA Series
Old 12-06-10, 03:52 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
It's possible you need a new pressure switch but not likely. Far more pressure switches are replaced than need be. Most likely you have some kind of restriction. Sometimes it's as simple as a piece of rust or other crud blocking the hole where the hose connects on either end. Another common problem is a partially blocked either intake or exhaust pipe.
