Pilot ignition module...
We have this style that needs to be replaced..
This is what was sent when we ordered a new one. It looks like it will work (do you agree?), but what concerns me is the spark wire connector. When we unplug it from the old one above, will it have the same style connectors as the new?
Obviously you have a Lennox furnace. The replacement control you show should work on a G-20 Whisperheat. However if you have a furnace such as a G-26, you have a prepurge period prior to ignition which may not be provided by this control. Could lead to undesired ignition. Lennox has a retrofit Honeywell module to replace the johnson controls module. Those johnson modules have been known to have problems.
