HEAT PUMP
Old 12-20-00, 02:36 AM
Guest
Question
I live in columbia sc, my heat pump is on, the thermostat is set how it is supposed to be, fen is on "auto" , the AUX. came on , temp. is set 72.
But heat is not coming from the vents,there is a burning odor from the ventc.HELP
Old 12-20-00, 05:38 AM
R-12guy
sounds like your fan isnt coming on for what ever reason...fan relay, bad motor, bad capicator..call some one be fore you make matters worse
Old 12-20-00, 12:53 PM
Guest
Originally posted by hadzia
I live in columbia sc, my heat pump is on, the thermostat is set how it is supposed to be, fan is on "auto" , the AUX. came on , temp. is set 72.
I SET TEMP. 80 AFTER THAT, HEAT IS COMING FROM THE VENTS
Old 12-20-00, 01:54 PM
PDF
NEED MORE INFO
You said you set tstat at 80 and you had heat.Is the blower running?Do you feel air coming from the vents?The burning could have been your electric heat cycling on for the first time and burning dust off the elements.Add more info for more help.PDF
Old 12-20-00, 05:58 PM
fjrachel
S.C. just had a bad cold snap. Your heat pump can't keep up with the cold, wet weather and your aux heat is coming on and is burning off dust accumulation. Or you've lost a blower motor and you would not get anything from the vents cold or warm air.
Old 12-20-00, 07:33 PM
Guest
add
blower motor (fan) sometimes works when I set temp.-80-or more.
Old 12-21-00, 02:52 PM
PDF
IT'S TECH TIME !!!!!!!
You have a lot of things going on at once,call a TECH.Preferably a company with the brand name of your equipment.Keep us clued in on what happens.PDF
Old 12-21-00, 04:43 PM
fjrachel
Agreed, call a tech.
