Error: Pressure Switch Stuck Open/Closed
Old 12-18-10, 11:15 AM
T
One of my furnaces is giving the Pressure Switch Stuck error. I've swapped the switch and hose with my other furnace and it still doesn't work. The other furnace continues to work with swapped parts.
Here's the sequence of what is working on the non-functioning gas furnace:
inducer fan turns on
gas is ignited
just as the blower fan is turning on to blow the heat into the house the flame goes out--hence only cold air is blown.
at this point the LED indicator displays the code for Pressure Switch Stuck open/closed.
Should I swap the mother board or is there another best next step?
Old 12-19-10, 07:13 AM
problem
you have e venting problem.is this a 80 or 90 percent unit.for a 90 percent unit ,it will use pvc pipes...you need to check for obstructions in the piping. if it uses 2 pvc pipes then you must check both...if yo are sure the venting system is clear...then the other possibility is that yo have a crack in the heat exchanger..get a carbon monoxide detector...what make and model is this?
