still heat pump ?
Old 12-20-00, 04:44 PM
Guest
Question
I STILL HAVE PROBLEM WITH H. PUMP
OK --H.PUMP IS ON,FAN IS ON "AUTO" ,
WHEN I SET TEMP. 70-OR-72-OR-74-HEAT IS NOT COMING FROM THE VENTS(INSIDE FAN DOESN'T WORKS).
WHEN I SET TEMP. 80-OR-82-OR-84-AFTER THAT,FAN STARTS AND
I FEEL HEAT IS COMING FROM THE VENTS.
AFTER THAT I SET TEMP.--72-OR--74--FAN IS STILL WORKING (HEAT IS COMING FROM THE VENTS).
INSIDE TEMP. IS 65-TO-70 . HELPPPPPP
Old 12-20-00, 06:15 PM
fjrachel
After your 80 back to 72, how long does the fan run?
Old 12-20-00, 07:12 PM
Guest
add
THE FAN RUNS 10-TO-15 MIN. AND STOPS.
--(NOW FAN DOESN'T WORK ? ,I SET TEMP. 80-82
AUX IS ON, OUTSIDE FAN WORKS )???????
WE ARE COLD HELPPP.
[Edited by hadzia on 12-20-00 at 10:21]
Old 12-21-00, 02:59 PM
PDF
IT' TECH TIME!!!!!
Hopefully you have a bad capacitor or a bad lead feeding the fan motor.PDF
Old 12-21-00, 04:41 PM
fjrachel
Sorry, follow PDF's advice and call a tech.
