help with register bleeding
Old 12-20-00, 07:23 PM
Guest
Exclamation
I am bleeding the registers in my apartment because they are way too noisy. Some registers I get just water out of and others I get spitting steam. I have left the steam ones open for up to 5 minutes and still only get gurgley steam. Should I be getting water or steam from the valves? Please help, I need some sleep!
jon
Old 12-21-00, 08:43 PM
Guest
you need to find out if you have steam heat or hot water. I'm guessing you have steam and some steam traps are not working properly. This would back water up in your radiators allowing little heating. Steam will hiss during operation. this is normal. get used to it.
