Rheem inducer fun runs continously
Old 12-22-10, 07:07 AM
Hello,
The inducer fun keeps on running after the heat cycle ends.
The only way to get the heater to reset and start to heat on next cycle is to turn off and on main switch.
The unit is a RHEEM RGDE-14ERAJR
Thank you.
Old 12-22-10, 07:32 AM
SeattlePioneer's Avatar
disconnect the wire at the W terminal on the furnace. If the inducer fan continues to run you have a relay sticking closed on the circuit board or ignition module and that part needs to be replaced.
