My beckett oil burner can't turn off at thermostat.
Old 12-25-10, 06:00 PM
R
Unhappy My beckett oil burner can't turn off at thermostat.
I recently purchased a house. I have a Beckett AF model burner. I turn on the heat, but can't turn off with the thermostat. Please give me advise. Thank you.
Old 12-25-10, 06:13 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Try disconnecting the themostat wires either at the furnace or the thermostat. If the burner shuts off, there is either a problem with the stat or wiring.
If the blower is the problem & not the burner, the source is likely a stuck fan switch.
Old 12-27-10, 05:49 AM
R
Thank You Grady! It is the thermostat cause the problem. It working fine now, after replacing the it.
