Fan Switch ID?
Old 12-27-10, 03:28 PM
D
Fan Switch ID?
Hello,
I have a fan switch that needs to be replaced on an old Gaffers and Sattler furnace. I have searched online for a replacement but cannot find anything similar to what I have. I am not even sure if this is the correct fan switch for this unit. Below is a picture of the switch. any help would be great. Thank you.
http://i1134.photobucket.com/albums/...jpg?1293492367
Old 12-27-10, 04:26 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
That looks like a Cam-Stat fan switch. You need to remove it & measure the length. There might be something here:
furnaceparts.com - Camstat
Old 12-28-10, 02:38 PM
D
Thank you for the reply. There are some similar switches on that site. The furnace is a Gaffers and Sattler 125 FEF and I think this limit switch is not the correct one. Any idea what the correct limit switch would be? Thank you.
Tom
Old 12-28-10, 03:12 PM
D
the picture you are showing is for a fan switch...looks like bi-metal type....if you take it off you will see if the back side is flush or extends into the furnace...are you sure this is the switch you need to replace?
Old 12-28-10, 04:35 PM
D
Yes. This switch is not working correctly. It is sticking in the on position so the fan runs continuously. It extends into the furnace about 4 inches but looks like nothing I have seen online. All of the switches I have seen have a round part which extends into the furnace and this one is rectangular in shape and as large as the front of the switch. So it is about 4 inches long by 3/4 of an inch wide and 2 inches tall.
Thanks
Tom
Old 12-28-10, 04:40 PM
Grady's Avatar
Certainly sounds like a CamStat. Now that you have it out, how about posting a picture or three.
Old 12-28-10, 05:48 PM
D
That would be perfect...However, this heater is at my mothers house about 75 miles away. I wish I would have taken more pictures. I will get more pictures next time I am there.
Thanks,
Tom
Old 12-28-10, 06:27 PM
D
Here is a side view drawing from memory. I don't know if it will help.
http://i1134.photobucket.com/albums/...g?t=1293589596
Thanks,
Tom
Old 12-28-10, 06:33 PM
Grady's Avatar
Honestly, the brand & shape are secondary. Insertion depth is the biggest factor. Most furnaces in which Cam-Stat controls were used couldn't take the deeper insertion of another fan control. FYI, most Cam-Stat controls are wedge shaped other than the rectangular mounting plate.
Old 12-28-10, 06:52 PM
Received 3 Upvotes on 3 Posts
You will probably do yourself a favor, if you use another Camstat fan switch. Camstat's element that extends into the heat exchanger are narrow and tall compared to other brands. The opening inmost furnace brands that use this switch, the HX is designed for this switch.
Old 12-29-10, 04:40 AM
D
Thanks for the replies guys. I will be looking for a Camstat switch with the same length element. Your help is much appreciated.
Thank you,
Tom
