Gas Trane Furnace Problem
Hi this morning my furnace stopped working on me. It's a 2 stage Gas Trane furnace I believe the series is XL80.
The thermostat is Luxpro psp511, I set the thermostat at 68 degrees but when I woke up it was at 53 degrees, the furnace did not kick in at all. I sometimes can manually turn on the furnace with the thermostat.
When I manually turn it on. It fires up normally. No trouble flashing coming from the furnace. Everything is normal. Once it reaches the temp I set it for it turns off and doesn't turn back on when the temp goes down. Any ideas?
I had trouble with my lux pros also. I have the 500B's. Sometimes the heat will not come on and we will wake up to a cold house. Now I determained two thing may be wrong but am not sure which one it is.
1) Its the common t stat in living room and used often. Up---down----up---down. Wife likes hot, I like to lower,kids just touch it when they are not supposed to. So I thought the button was getting stuck and for some reason it would not kick on.
2) Even though the low battery light was not on I put fresh batterys in. Have not had an issue since the battery change.
I dont like these t stats and when I get the money I will buy a different brand.
Mike NJ
Mike NJ
