York Diamond 90 Furnace
Old 01-05-11, 10:32 AM
I have a York Diamond 90 furnace, which will only blow cold air, 4 flashes of red light on control board, what is my next step? I don't have an error code sheet, but from what I can gather 4 flashes means bad open limit switch. Where is the limit switch, how can I verify it is bad?
Old 01-05-11, 04:07 PM
ther could be more than 1 limit switch.try a serach and locate one for york furnaces.many tines there is one byt the burner assembly.i would change the air filter if you have not done it already.
