Gas fired boler
I have a gas fired boiler for my baseboard hot water system. I have two floors and two zones. Over the past week or so we have developed a noise in the boiler. It's a light knocking sound. It's almost as if there is air in the system, but only in the boiler, nothing is heard in any of the piping or radiation sections. It is irregular in the rhythm that it develops and almost sounds like other applications where metal is getting hot and then cooling down, but it has never done this in the past.Is there something obvious I could look for? Nothing in the system has been changed. Thank-you.
Gas fired boiler
Henry, I took a look at the Extrol tank, but I'm not exactly sure what I'm looking for? The tank, BTW, seems to have some kind of oily residue building up on the top that is maybe leaking from the bleeder itself (on top of the bleeder)? I'm not clear on the function of the schrader valve on the top, or the valve on the bottom of the tank. When should they be checked and what should I find. I forgot to mention in my previous post, that I also flushed the boiler as one of my first attempts to fix this problem, but only so far as closing the zones, opening the drain and letting the fill valve run water through the boiler for awhile. Thanks.
gas fired boiler
Hi Henry,
I replaced the bleeder today, but no help. Still has the same noise in the boiler. I'm not sure what you meant by 'dirty' installation, but I'm assuming you mean that the unit wasn't clean enpough when it was installed? We did run boiler coloid through the system when it was new. We installed this system about 12 years ago and this has been the first problem. Also, I wanted to mention that the boiler is running about 25 psi. It seem like it used to be around 20 psi, but I'm not sure. The boiler is rated at 30 psi and the fill valve has a 25 psi limit and set range of 12-15 psi. Is it possible the pressure is too high? As I said before, the pressure relief valve does not pop off, but it does function. Any other suggestions? I still haven't found anything else obviously suspect. Thanks.
