Tempstar HE Furnace won't stay lit
Old 01-05-11, 08:07 PM
K
I have a Tempstar gas furnace. The furnace doesn't always light after the blower start. The vac switch is operating properly. Periodically I hear the blower running without flame in the burner. I have to turn off the furnace or cycle the thermostat, and when I restart I've found that if I 'tap' the gas valve then the pilot will light and the then the burner. Occasionally, during operation the burner will flame out and I hear the gas valve clicking like its trying, but sometimes it won't relight until I reset the system.
I'm thinking its the valve?
Old 01-05-11, 08:13 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
sounds like you have a "dumb" valve and that is most likely your problem
Old 01-05-11, 08:52 PM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
Use an AC voltmeter to see if you have 24 VAC being supplied reliably to the valve. If you do, you have a bad valve.
If you don't it might be a bad circuit board.
Also, checking to be sure you have a reliable gas supply would be a worthwhile.
