it's really cold in here
a few weeks ago we ran out of propane. we got more propane, but the poliot light refuses to light. the water heater poliot lit right away. any clues as to what i can do. we have had no heat for 3 weeks and it's now -40 degrees outside.
Any flame at all?
Do you get any flame at all when you try and light the pilot?Is the valve set to pilot and it pushs down in the slot?If no flame at all R-12 Guy has a good point.The pilot orifice can be plugged.You will need to CAREFULLY remove the pilot assembly(probably 7/16 wrench).Disassemble pilot,you will need a very thin piece of wire,a broach or a "CATS WHISKER".What the heck is a cats whisker?Anyways you need to clean the VERY tiny hole inside the orifice.Give us a call back let us know how you are doing.PDF
