Fan and limit controller
Old 12-21-00, 10:16 PM
Guest
Unhappy
I but a new fan and limit controller, but I can't seem to get it to work right. The fan runs constantly, and the heat cycle is very short (flames come up for about 45 seconds, then die down). How can I set the fan-off/on levers to get system to work properly?. On my last try, I set the fan off lever very low (70), and the fan on lever is set to 110. What do you suggest?
Old 12-22-00, 12:10 PM
PDF
Some info
Your new control was set to go and did not need any adjustment.Place the fan start to 150 and the other to 100 and give it a try.Your flame problem is do to other situations and you probably need a TECH.PDF
