Vent Fan
Old 12-22-00, 05:34 AM
Guest
Unhappy
Thanks for the earlier replies. . . the fan that is running almost continuously (cycling on off every 5 to 8 seconds) is the vent fan - the furnace fan seems to run fine after checking it as you suggested.
The vent fan is connected to what appears to be a 3" circular (vacuum sensor? mechanical solenoid?) unit with two wires and two clear plastic tubes connected to it. . . when I pinch off the clear tube going to the side of the unit labeled "blower" the fan goes off. . . .
Any ideas? Is this something I can take care of my self?
Is there a way to test the unit?
Thanks!
Old 12-22-00, 03:30 PM
fjrachel
Please keep your replies in your original post so we can follow the progress. But it sounds as though you will have to call a tech.
