Intermittent Pilot Ignition module repair question
Old 01-13-11, 10:21 AM
Hi,
Are there any user serviceable part inside an intermittent pilot ignition module from Lennox, model G776RGD-2? I find that the blower works, but the gas won't light, unless I hold the THS2 wire steady so that the light above it stays on for 15 seconds. Since I can't hold the wire every time I want the gas to light, and since it doesn't seem to be a wire issue, it must be something loose inside the module. Can I remove the module, open it up, correct whatever is flaky inside, and put it back, or do I have to replace the entire module? I found one on the internet for 138.00 but most are over 200.00. What do you suggest?
Old 01-13-11, 03:29 PM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
S8610U3009 this is a universal spark board replacement
Old 01-13-11, 04:09 PM
big bang theory
do not tamper with the module,if you blow your house up,no insurance company will pay on the claim. they are normally not field repairable...buy a new one..
Old 01-13-11, 04:40 PM
Here's one that replaces it
Lennox Upgrade Furnace Contol Kit 30W33
I looked at the one you mentioned but it didn't have my model number in the manual as one that it replaces.
Old 01-13-11, 05:19 PM
hvactechfw's Avatar
well, kinda, it replaces the one you get with the 30w33 kit which is a s8670k
