York Diamond 90 intermittent heat
Old 01-14-11, 06:38 AM
I had heat until last night. Then just cold air blowing. I replaced the air filter (it had been a while), shut down the unit, restarted, and everything came back on. Run fine until sometime during the night when it started blowing cold air again. I have tried to watch what is happening when I stop and restart. Most times I can see it restart, but it only stays on for a few minutes before the flames go out and I am left with cold air again. Resetting the system works, but not for long.
Help!
Old 01-14-11, 07:49 AM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
You need to take the front cover concealing the burner compartment and carefully observe and report the sequence of events which occur when you turn up the thermostat.
And post the model number of the furnace which is on the rating plate in the burner compartment.
Old 01-15-11, 05:22 AM
I managed to get the furnance restarted yesterdaay, but it dies again around 7 pm. Now when it tries to go on, the blower fan starts first, then nothing else. I don't hear the inducer blower, I never see the heating element light, I don't hear the gas switch go on.
Old 01-15-11, 05:50 AM
hvactechfw's Avatar
Received 4 Upvotes on 4 Posts
check for diagnostic LED flash on control board. try to look for this through blower door window
Old 01-15-11, 06:04 AM
If the inducer motor isn't starting you need to use an AC voltmeter to check and see if the thermostat is turning the furnace on. if it is, check to see if the inducer motor has 120 VAC being supplied to it.
Old 01-15-11, 06:08 AM
hvactechfw's Avatar
if it is in fault status the inducer may not start. Check for codes first.
Old 01-15-11, 08:10 PM
Fixed?
I have not ben getting any errors from the led. I did find that the switch on the lower panel was sticking. Got that working again and it seems to be working ok. Could that have ben the issue?
