It's winter and I have no heat!!!
Old 01-18-11, 04:33 PM
G
I have a 1982 (I think) Duomatic Olsen fuel oil furnace. I didn't realize it was an oil furnace until it stopped working. I just had 200 gallons of fuel dropped, but now my furnace wont turn on.
I have no idea what I am doing here. I need help.
Any help will be greatly appreciated!!!
Old 01-18-11, 05:04 PM
Grady's Avatar
Received 39 Upvotes on 37 Posts
Did you run out of oil? If you did, the pump on the furnace may need to be bled to get the air out & fuel in.
Old 01-18-11, 05:23 PM
G
Yes, it ran out of oil. How would I go about getting the air bled out?
Old 01-18-11, 05:35 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Read this it should help, but Grady may know a few tricks.
How To Bleed An Oil Burner After Running Out Of Fuel
Mike NJ
Old 01-18-11, 08:33 PM
G
I founf the bleeder screw. However, there are 2 buttons. One says push to reset, but it's not "out" so I can't push it in. The other, I believe, is the ignitor button. Can I push that button when trying to bleed the pump? The furnace kicks on when I push the "ignitor" button, for about 30 seconds and then shuts off. Any suggestions?
Old 01-18-11, 08:50 PM
lawrosa's Avatar
Super Moderator
I think your locked out and you have to hold the reset button down for 10 seconds or so. Is there one oil line or two. Is two it should purge itself just hold down the reset to get out of lock out.
post back if it dont work.
Mike NJ
Old 01-18-11, 08:58 PM
G
I can't push the button in, it is flush against the casing. The only button I can push is the one that makes the burner kick on, the one I believe to be the ignitor button, because this furnace has an electric ignitor. There is only one fuel line running from the tank.
Old 01-18-11, 09:24 PM
lawrosa's Avatar
Super Moderator
Does the pump run when you push the other button and ir fires up?
I assume the pump should be running if the reset button is in and there is power to the unit and the t stat is calling for heat..
The other button test the electrode I think...
What is the burner make and model...
Mike NJ
Old 01-18-11, 09:45 PM
G
The burner is a DUO-MATIC OLSEN model AF 65YB.
There's nothing wrong with the power, everything works except the burner won't ignite.
Old 01-19-11, 02:45 PM
lawrosa's Avatar
Super Moderator
I got your PM.
Did you fix your issue? It got late and I am not a oil guy and was hoping someone more experienced chimed in. I think furd knows or Trooper but they did not come back on line. I dont know what that other button is for and I did not want you to flood the chamber trying to prime.
Mike NJ
Old 01-19-11, 04:50 PM
Grady's Avatar
Gina1
Hope you got it up & running. Sorry I couldn't stay & help but had to go out & work on a couple of heaters. Didn't get home until 2:00 AM, back up at 5:30 for another day of heater service.
