Arcoflame Oil Burner leaking fumes.
Old 01-19-11, 10:15 AM
E
Hi there, I am trying to help my grandfather find the part he needs to fix his furnace but I can't find it on the internet. The furnace is leaking fumes on start-up.
On the diagram in the instruction manual it shows the part being called a pressure plate and it puts pressure on the insulation sealing the ignitor tube and burner plate. The burner is an Acroflame Oil Burner Model-DH
Any help is much appreciated, any websites that may carry the parts are also appreciated.
Thanks, Zack
Old 01-19-11, 06:19 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Zack, I hate to tell you this but that burner has to be at least 40-50 years old. You can still buy motors, pumps, ignition transformers, etc. for it because they fix a multitude of burners but internal parts such as the one you want are no longer made.
Patriot-Supply.com carries a large selection of oil burner & boiler parts.
