Horizontal furnace- filter direction
I have a ducane horizontal furnace in my crawl space with duct work on both ends. How can I tell which way the air is blowing without turning the furnace on? I don't know which way to put the filter in- It seems that there is the main body of the furnace at one end, and the other end is a box?
Thanks,
Thanks,
If you can see which end has the ducts going to various rooms, it is the opposite end for the filter. You may consider installing a "return filter grille" where the return grille is located in the house. Makes it a lot easier to change the filter.
this would be fine if there is (we don't know) only one return. Some homes, and properly ducted homes have a return in every room
