Heat pump clunking
Old 12-24-00, 11:18 AM
Question
We are new to heat pumps and have a Coleman Evcon Presidential system. It has started clunking right after the fan shuts down. Any ideas as to where to start looking for the cause?
Old 12-24-00, 12:20 PM
fjrachel
Which fan? indoor or outdoor? Sounds as though blower or fan prop is out of balance.
Old 12-24-00, 02:46 PM
PDF
Not sure of question?????
What is it that starts clunking when the fan shuts off???The fan???The compressor???What is the it that clunks???PDF
Old 12-24-00, 07:47 PM
The indoor fan shuts off, and the outside compressor clunks right after.
Old 12-25-00, 03:17 AM
PDF
Okay
Possible reasons>>>>>High head pressure,bad internal mounting spring,worn piston or rod bearing.If you are getting sufficient heat,you can probably rule out bad piston and/or valve.PDF
Old 12-25-00, 01:47 PM
Smile
Thank you for your responses. It makes sense that it's something out of balance, or worn due to being unlevel. We just bought this house a few months ago, was told the heat pump was not level, had it levelled, and have just started using it to heat. We'll be calling for service. Your information should help us from getting raked over the coals for not knowing what could be wrong. Thanks again.
Old 12-26-00, 05:11 AM
PDF
K.C.G.
CHECK THE WARRANTY YOU RECEIVED WHEN YOU PURCHASED YOUR HOME.HP REPAIRS CAN BE VERY EXPENSIVE!!!!!!!!!!!
Old 12-26-00, 09:51 AM
Smile
Good advice we'll take. Also, we realized we have a friend who is in the business, and will be able to get his help with this. Thankyou for your help and advice. Happy Holidays......KCG
