Lp conversion
Received 0 Votes
Lp conversion
Im replacing the furnace in my house and would like to use the old one in my garage. it is a lennox pulse 21 (G21Q3-80-1). I can't seem to find an Lp conversion kit for under $300. I can buy a used Lp furnace for that! Any ideas or places on the cheap? Thanks!
Silly Question
Why do you want to convert the funace to LP if you have natural available? I would think it would be much cheaper to extend the natural into the garage than convert to & operate on LP.
Received 0 Votes
Lp conversion
Well, I thought of that too but I have a detatched garage and i don't heat the garage more than a couple times a winter. suppose I should seriosly look into it cost wise! Thanks
Received 0 Votes
frozen condensate traps
One more question. I'm looking to put that condensing furnace in my garage, I don't want to run it all the time so it WILL freeze. I'm wondering if i can run the exhaust the 3 feet out the wall with maybe 1'' or so drop with no trap? thanks again for the help!
Received 0 Votes
I guess the worst I could do is try it, the furnace is junk anyways. Their can't be that much water there with a straight pipe and no trap?? I'll let you know next winter if I have any problems. Thanks
