BANGING AND RATTLING BOILER---SAFETY VALVE BLOWS
Old 12-25-00, 08:30 AM
Guest
I HAVE TWO PROBLEMS ----(ARE THEY RELATED) ?????
FIRST IS THAT I HAVE BANGING AND RATTLING AT THE SUPPLY SIDE
PIPES FROM MY BOILER...NOT STEADY...ONLY OCCASIONALLY.
SECOND IS THAT MY SAFETY VALVE BLOWS OCCASIONALLY...ABOUT
HALF A BUCKET EVERY WEEK.
THIS IS A HOT WATER CLOSED LOOP GAS FIRED BASEBOARD HEATING
SYSTEM WITH 4 CIRCULATOR PUMP ZONES.
I HAVE TRIED A NEW PRESSURE REGULATOR VALVE,A NEW SAFETY
VALVE AND HAVE DRAINED THE EXPANSION TANK...NOTHING SEEMS TO
HELP. I TRIED CLOSING OFF THE WATER SUPPLY VALVE WHICH BRINGS THE ALTITUDE PRESSURE DOWN TO 10 POUNDS AND THIS STOPS THE VALVE FROM BLOWING,BUT I AM AFRAID TO LEAVE IT THIS WAY PERMANENTLY BECAUSE THE BOILER MAY BE DAMAGED BY LOW WATER.
WILL APPREIATE ANY IDEAS OR SUGGESTIONS. THANK YOU
LEONARD BECKER [email protected]
VALVE AND HAVE DRAINED THE EXPANSION TANK !!!!
NOTHING SEMS TO HELP
Old 12-25-00, 08:35 AM
fjrachel
Hot water boilers are to be run at 12psi.
Old 12-25-00, 07:43 PM
Guest
have you looked at your fresh water intake. that is the easiest way to increase pressure in a water system. make sure the valve is not bleeding thru. also check the temp on the boiler. is it over firing. only need 140 deg F water for good heating. also pressure is different with each system. might only need a few psi for sufficient heating.
