noisy air intake
Old 02-08-11, 08:01 AM
noisy air intake
Had a new force air installed in a pantry area . It has one intake air vent and is extremely noisy .Is there a way to quite the fresh air intake?
(e-mail address removed. Not allowed.)
Any help will be greatly appreciated...........Thank you..JJ
Old 02-08-11, 09:14 AM
SeattlePioneer's Avatar
Received 1 Upvote on 1 Post
The usual cause is ductwork that is too small that requires air velocities that are excessively high, causing noise.
You should complain to the contractor that designed and installed your system, and do so promptly.
Old 02-17-11, 05:39 PM
E
bend the fins on the intake vent until the noise stops, open them up a bit more to allow for more air to be sucked in.
