heat pump moans/groans
Old 12-26-00, 10:32 AM
Guest
when the heat pump cycles off and the outside fan is still running, the unit has a hard moan/groan to it. Is there something that needs lubrication? It is a carrier model 38ay030300.
Old 12-26-00, 01:06 PM
PDF
Compressor problems
Something is kicking the comp. off.It should keep running until temp. is satisfied inside.Comp and fan should be running together.Does this happen after 10 to 30 secs. after start up?If so a start or run component could be defective.Check to make sure air filter is not plugged and air flow thtu vents is good, and no vents closed.PDF
