Mounting older counterflow gas furnace sideways
Does anyone know if it's okay to mount an older counterflow natural gas furnace on its side? I know the newer units are okay sideways, but not sure about the older ones. I just pulled a working unit out of a repo house I'm renovating and considering reusing this furnace in my workshop.
The furnace is approximately from 1988, 80+ power vented natural gas, 3" vent, I believe 80k btu. Squirrel cage works good, induction blower works good, burner seems to work good. I would basically hang it from the ceiling with none or minimal ducting other than a filter rack on the intake.
The plate on the front panel reads "Kenmore Power Miser 80".
The label inside the service compartment:
Manufactured by HQCO Lavergne, TN
Model No.: NDGE050AD01 867.768310
Ser No.: L904533254
Input BTU: 50,000
There is also a wiring diagram and a number of basic safety and operation stickers, but nothing regarding installation or mounting orientation.
Ser No.: L904533254
Input BTU: 50,000
Most HQ counterflow units are made to be installed as counterflow only. The newer ones with an 'M' in the model number are multi-position. Your's was made in 1990, 45th week.
