furnace won't stay lit
I have a comfortmaker RPJ ll natural gas furnace. The problem I am having is it will light the burner and stay on for a second or two then the burner will shut off. I will get a steady flashing light at the control unit which I am sure you are aware of means no call for heat. I have replaced the flame sensor and the rollout sensor in the past ( maybe a year ago). It seems as though this problem is intermittent. Since some times the furnace works great and like now it does not. It is always flashing the same code, steady. Thanks in advance for any help to resolve my problem
I cleaned the flame sensor like you said and so far so good. Can't thank you enough. I will let you know tomorrow if it is still working propoerly. Again, thank you very much.
