electric furnace blowing cool air
Old 12-28-00, 07:52 AM
Guest
Post
my electric furnace is blowing cool..the temperature setting is high and the heat is getting no warmer in my home...what should i do????
Old 12-28-00, 10:59 AM
PDF
ELECTRIC FURNACE OR HEAT PUMP?????
If you have an electric and JUST an electric furnace,check your circuit breakers.Turn the breakers to complete off then back to on.If they trip you have problems.If it is an electric furnace and you reset breakers and get heat,you might still need a TECH.The electric heat runs in stages.You may have a section of strip heat not working or burnt outPDF
