Litman Chimney Elbow
Old 03-31-11, 06:37 AM
smite314's Avatar
Good morning!
I was wondering if anyone on the forum has heard of or successfully installed a "Litman Chimney Elbow". I've searched the Interwebs and only found reference to it on a few sites, such as How to Diagnose Oil Burner Noise, Smoke, Odors - Defects & Operating Problems Found on Hot Water Heating Boilers which states:
" Litman chimney elbow: Lanthier describes an idea from Roger Litman (North Shore Fuel) who adds an elbow at the end of a flue pipe run in the base of a chimney to reduce chimney noise. The elbow both reduced noise and improved chimney draft, perhaps because the elbow adds length and thus velocity to incoming chimney vent products. Add a drainage hole in the low point of the elbow, and "get the outlet of the elbow to angle about 15 degrees to the base". "
Thoughts? Successes? Criticisms?
Thanks in advance!
-Chris
Old 03-31-11, 04:40 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
I've never seen or heard of one but it sounds like it is contrary to any installation instructions I've ever seen.
