Goddman GMS8 3 flash
I have the same three blinking lights on Goodman GMS8. I tried the trick of cleaning the nipple with the 1/16 bit. it worked great for two days and now I am back to again the three blinking lights. I have cleaned it twice using the bit, it works for a couple of days and then it stops working.
Any suggestions, Can i put WD40 in it?
Thanks
Thanks
Last edited by hvactechfw; 03-31-11 at 12:28 PM. Reason: do not hijack another thread, it can become confusing on which problem you are talking about between different poster's
How is the tubing from the inducer motor to the pressure switch routed. I ask because mine once had a sag - think "P" trap - in it and enough moisture built up to prevent the pressure switch from working. After draining the tubing and tying it to prevent the sag, I have had no further problems.
Look again the line gos from the pressure switch down hill to the bend and then back up hill, so you have a real big low trap in that line that can hold water.
